IDE > SATA convertor
19 Jul 2005
S. Yorkshire
No, not the normal one that will allow an IDE drive to be used on a SATA board, but the opposite.
I need to use a SATA drive on a board with only IDE ports.
I can't find anything to do this that doesn't look like the former type which is of no use.
Can anyone point me in the right direction, or as you can't post links, at least tell me how to search for the right thing?
Thanks
I`m using the Addonics ADSAIDE SATA to IDE Converter Adapter to connect my SATA DVD Drive to one of my IDE ports and it works wonders. This converter adapter also works with SATA Hard Drives as well.
Description:
The SATA - IDE/ATAPI converter is a perfect solution for converting the Serial ATA hard drive or Serial ATA optical storage devices to standard IDE interface. Just simply attach this converter to the back of any SATA storage device, instantly the Serial ATA drive can be used as a standard IDE or ATAPI device in all kinds of applications that have been tested and certified for IDE storage
Specifications:
Serial ATA 1.0 compliant
Convert any Serial ATA hard drive or Serial ATA storage device into IDE hard drive or ATAPI devices
Support ATA 33/66/100/133
48 bits LBA. Support large hard drives of 137 GB or larger with one partition
Mini Board size (75mm x 26mm). Mount directly to the back of SATA hard drive
Bootable
Simple plug and play, no drivers required
Compatible with any OS (Windows, DOS, Mac, Linux, UNIX..) that supports IDE or ATAPI storage devices
Supports Spread Spectrum in receiver
Compliant with ATA specifications
Connectors:
input: combo SATA 15-pin power and 7-pin data connector (direct attach to SATA hard drive)
output: 40-pin IDE male connector (work with standard IDE connecting cable)
power: floppy style connector
1 year warranty
