IDE to USB
shiner said:
thanks guys wondered how well these worked
They work pretty well, if its a 2.5 inch hdd then you dont need external power but 3.5 desktop hdds use an external power supply. If it is a 3.5 incher make sure you turn it on and let it spin up before you plug it into the pc otherwise it reports the drive as unknown.
