- 24 Oct 2002
- Portsmouth
I'm just speccing up a TV for my room. The distance between where I will be sitting and the wall the screen will be mounted on is 2.5m (250cm) exactly.
My housemates 32" tv looks small at a distance of about 2 metres which is why I thought I would ask the question.
My budget recommend that I buy a 40" screen but I'm concerned this would be too small and not the 'optimal' screensize for viewing.
While I'd rather not splash out for a 46" I will only want to buy my TV once and it will last a long time so should I save a little longer and buy the 46"?
It will mostly be used for bluerays and other HDTV content courtesy of Virgin+ or Freesat.
