Ideas on Cable Management for small case
19 Sep 2016
Jensen's Leather Jacket
Folks, I need some help..
The situation is this.. New build. Non modular PSU, Dinky Case.
Can anyone suggest possible better routing or if I could do something tidier if I had some extension cables?
this is the first properly managed build i've done so any help would be appreciated.
It doesn't look that bad, I've seen worse :D
Are you able to route the 8 pin CPU power cable from above? Also try routing the PCIE power cable from directly behind the graphics card instead of the drive bay?
Also tuck those unused cables at the front to under the HDD.
