Identify a problem
10 May 2007
Kent
I'm pretty stumped. I have no idea what the problem is.
Basically, a few nights ago my PC shut down (BSOD) while playing a game, I booted it up and then my Ventrilo/Winamp wasn't recognizing any DirectSound.
So I rebooted again, next time around they worked. Then I tried to load a game which was Counter Strike 1.6, and when trying to join a server it says unable to find model blah blah (this was a LAN server, nothing I needed to download). I had to reinstall steam and CS to get CS to run, and at the time CS was running great after that.
Now after all this, I loaded mIRC while playing CS to try and find a match, and my CS just started to feel all sluggish, it feels like a graphic issue but I get 100frames constant, but when I jump the screen doesn't update properly. It's hard to explain, but it doesn't feel smooth at all.
I have reformatted completely and it's still got the same problem, and I have tried a different game also after the reformat which was Quake 4..
What do you guys think it could be? I've stress tested memory, CPU and GFX and nothing.
I've re-installed the graphics drivers to the latest ones about 4/5 times, and I've reset BIOS settings to fail-safe defaults (F8 revision)
In nvidia control panel,have you set it to single display mode?
Also if your using a flat screen has you turned V sync off?
This can cause probs.
EDIT or even turn off V sync in the game..
Sounds like something might have become corrupted when the BSOD occured. Have you run the chkdsk utility to see if there are any errors on your disk?
