as the link above.. when asked for team number you put in the number 10
Also new folders will notice your points a bit low this is you will not receive bonus points i think until you have completed ten work units..this makes a big difference
you need to apply for and use a pass key for the bonus
It also take approx 3 ish hours for your points to show
i keep track here http://folding.extremeoverclocking.com/user_list.php?s=&t=10
yes you can use you cpu and both cards whether it worth the cpu folding as it not very power efficient compared to the GPUs the 8350 will only get 10 to 20k the 2 cards may get when you have bonus 250k + (my lads 7990 which is two 7970s will hit 280k)
Yes I think I have it sorted now ... I have my system set to Medium Power in the FAH Control client and it seems to be completing and picking up new WU's ok
