IE 7 help
14 Aug 2005
Hi there
Seem to have a problem with some websites now - on some drop dop menus that give you options it will not let me in - it keeps coming up with pop-up blocked. I am now having problems with AOL, it won't let me send an email and it won't let me into my email. Anyone got any ideas? It has only happened within the last couple of days. I don't know if its an add on or something. Its driving me crazy!!
cheers
honky113
can you click on the pop-up blocked "bar" and it should allow you to temporarily enable popups for that site.
or in the tools/popup blocker/settings menu, you can exclude the site you're getting blocked on from the popup blocker.
I think it might be something to do with security settings.
Also, on the bottom left hand side of the screen there is a shield with an exclamation mark in it and at the bottom of the toolbar it is like a small screen with a circle and a line through it (like a no entry sign)
any ideas?
cheers
honky113
