Hey folks, requiring a bit of help here.
Basically i'm trying to get menu links in IE to not have any lower padding on them, so that the area below them don't overlap the drop-down's. As you can see from the pic's Firefox doesn't put any lower padding on it, which is what it's suppost to look like, and is what i'm trying to stop IE doing.
Viewing in IE
Viewing in Firefox
So far i've tried...
I'm pretty much stumped on what to try next, was hoping someone could have a quick look? I've included the css code below. Thanks.
Viewing in IE
Viewing in Firefox
- setting the drop-down sections z-index to -1, so they'll tuck behind the top links
- setting the padding and margins of the top links to 0
- setting the height of the top links (which messes things up completey)
Code:
/* style the outer div to give it width */
.campaignsmenu
margin: 5px 0 0 11px;
padding: 0;
position: relative;
z-index: 2;
height: 30px;
background: #000000;
font: normal 8pt arial, helvetica, sans-serif;
color: #658dbd;
/* remove all the bullets, borders and padding from the default list styling */
.campaignsmenu ul
padding: 0;
margin: 0;
list-style-type: none;
.campaignsmenu ul ul
width: 104px;
/* float the list to make it horizontal and a relative positon so that you can control the dropdown menu positon */
.campaignsmenu li
float: left;
/*width: 100px;*/
position: relative;
/* style the links for the top level */
.campaignsmenu a, .campaignsmenu a:visited, .campaignsmenu a:active
display: block;
text-decoration: none;
color: #658dbd;
background: #afafaf;
/* style the second level background */
.campaignsmenu ul ul a.drop, .campaignsmenu ul ul a.drop:visited, .campaignsmenu ul ul a.drop:active
background: #ffffff url('graphics/menu/menubackground1.jpg') repeat-x;
color: #658dbd;
/* style the second level links */
.campaignsmenu ul ul a.drop, .campaignsmenu a.drop:visited, .campaignsmenu a.drop:active
color: #658dbd;
/* style the second level hover */
.campaignsmenu ul ul a.drop:hover
background: #ffffff url('graphics/menu/menubackground2.jpg') repeat-x;
/* style the third level background */
.campaignsmenu ul ul ul a, .campaignsmenu ul ul ul a:visited, .campaignsmenu ul ul ul a:active
/* style the third level hover */
.campaignsmenu ul ul ul a:hover
/* hide the sub levels and give them a positon absolute so that they take up no room */
visibility: hidden;
position: absolute;
height: 0;
top: 15px;
left: 0px;
width: 150px;
/* same as above except pushes drop-downs left for end menu */
.campaignsmenu ul ul.endmenu
left: -36px;
/* another hack for IE5.5 */
* html .campaignsmenu ul ul
top: 14px;
t\op: 15px;
/* position the third level flyout menu */
left: 150px;
top: -1px;
width: 150px;
/* position the third level flyout menu for a left flyout */
.campaignsmenu ul ul ul.left
left: -150px;
/* style the table so that it takes no ppart in the layout - required for IE to work */
.table1 table
position: absolute;
top: 0;
left: 0;
.campaignsmenu ul ul a, .campaignsmenu ul ul a:visited, .campaignsmenu ul ul a:active
color: #658dbd;
height: auto;
line-height: 1em;
border: 1px solid #658dbd;
border-width: 0 1px 1px 1px;
padding: 5px 10px;
width: 129px
/* yet another hack for IE5.5 */
* html .campaignsmenu ul ul a
width: 150px;
w\idth: 129px;
/* style the top level hover */
.campaignsmenu a:hover, .campaignsmenu ul ul a:hover
color: #658dbd;
background: #f4cef5 url('graphics/menu/menubackground2.jpg') repeat-x;
/* make the second level visible when hover on first level list OR link */
.campaignsmenu ul :hover ul
visibility: visible;
/* keep the third level hidden when you hover on first level list OR link */
.campaignsmenu ul :hover ul ul
visibility: hidden;
/* keep the fourth level hidden when you hover on second level list OR link */
.campaignsmenu ul :hover ul :hover ul ul
visibility: hidden;
/* make the third level visible when you hover over second level list OR link */
/* make the fourth level visible when you hover over third level list OR link */
.campaignsmenu ul :hover ul :hover ul :hover ul
