ie4uinit.exe - Entry Point Not Found
The procedure entry point RunSetupCommandW could not be located in the dynamic link library ADVPACK.ddl
I want to dual boot Windows 7 x64 and Windows XP x86 (for 16-bit apps) and have started fresh install on seperate partitions (Installation went fine with Windows 7) but after install drivers/windows update and restart PC on Windows XP the above error message appears when clicking the username to log on.
This means that it has corrupted IE8 install plus Windows Explorer does not work i.e. right-click my computer > properties does not work as well as others.
Have tried uninstalling IE8 and installing again but it works but it takes 30 seconds for network connections to load and what seems like forever to load IE8. This is obviously not acceptable for a clean Windows installation.
Can anyone help me? I have already wasted discs and hours trying to get this f*king thing to work.
