If you were going to learn a programming language..
I don't mean to hijack the thread but can someone explain .NET to me? I have programming experiance in Java & PHP and have used C a few times, I have never really ventured to the MS side of programming. If I understand correctly .NET is like the Java VM and whereby programs are converted to some sort of bytecode then execured by the .NET runtime. I'm just a little confused with VB.NET and C#, C++ J++ etc.
Yeah it is more or less like the Java VM. Several languages can compile to CLR (that's the name of the .NET bytecode), VB, C# and I think it's possible to compile C++ into it but I'm not 100% sure on that (tbh I'm not sure why you'd want to, might as well use C#).
C#, or PHP, would be my choices. Both languages you can build functional things in quite easily and both capable of being used in serious projects.
If your are doing it for possible employment, then look where the market pays the most. I know that a decent C++ contractor with banking background pays around £60-£80 per hour depending on experience at our bank.
C#. It's a great language, it gives you great results quickly (which is pretty important when learning) and Visual Studio is pure sex. The Express Edition of Visual C# is free, too (download the 2008 beta).
Is Visual Studio 2005 the latest release (non-beta) version? Also what are the executables generated by .NET like? In Java you are using about 20MB od RAM before your program does anything.
Yep, with Service Pack 1.
Alas .NET is much the same. Obviously a lot depends on what assemblies are used within your project, but a vanilla C# WinForms application consumes around 15Mb, while a simple console app seems to grab around 14Mb.
a lot of people suggestiong java, just had something called processing.org a fairly new open-source language based on java suggested to me to use for my dissertation.
might want to give that a look. looks pretty good, havnt really done much research into it as im not v motivated atm
.net which one depends what you want..
.net is hugely powerful and simple. It is simply awesome compared to the others, especially if you use visual studio and not the free programs.
