Still on the search for a new monitor and just came across Iiyama. Really good prices and the specs look ok, but are they actually any good? Looking at this one in particular. Can you turn off the DCR? I have it on my LG multifunction and dont really like it that much, I prefer having my own settings. I want something that displays text well - my LG displays text quite fuzzy and so its horrible to read off of. Also needs to have nice looking colours - the LG is great at this (much nicer than my dell laptops which looks grey and dull in comparison), it just falls short on the text.
I've also been looking at the Samsung Pebble monitors. They look a bit nicer but I read on here that you dont always get a good panel whereas with Iiyama you're guaranteed a good samsung panel. Is that true, and so would the Iiyama image quality be the same as a Samsung?
Any other recommendations for 20" widescreens?
Cheers
Cheers
Text clarity and PQ can depend on a few things., but at least that model has a digital DVI-D interface which can help. Colour accuracy can really vary from one screen to another, and if you want decent colours, you may need to calibrate the screen, preferably with a hardware device. having said that, default colours of many modern screens tend to be very vivid and bright, and so if that is what you are looking for, as opposed to true accuracy, then you should be ok. I had a look at the 22"
