Just in case any of you IL2'ers have been asleep 4.09 is now official
http://forum.1cpublishing.eu/showthread.php?t=10276
damn...looking at them videos i was googling where to buy it from.
dont fancy purchasing it for the console..it will probably be too arcade like to hold my attention for too long.
is that patch for the original IL2 game?
that's the only my brother has
also, any reccomendations on a cheap-ish stick? I doubt our ms ines work in vista/7
I bought this game for 80p at a car boot sale
Absolute bargain!
Patch 4.09 Official English Language version, please check the Readme file carefuly when installing.
Warning
The current version 4.09m is not compatible with the previous versions of the flight simulator when playing over the network (Online). Both the server and client must have the appropriate versions in order to connect.
Attention: Version 4.09m is only for a merged version of the simulator of the proper version (FB+AEP+PF).
Add-On Installation Instructions (Please read carefully)
The Il-2 1946 add-on v.4.09m installs only over v.4.08m (1946 v4.08m DVD or FB+AEP+PF+46 merged v4.08m).
Addon 4.09m contains two separate parts:
1. 409m.exe – common for all and necessary for installation
2. skins409m.exe – contains the new default skins, if you wish to install them
Both installations 409m.exe or 409m.exe + skins409m.exe are compatible online
In order to install this add-on, run the file 409m.exe (or 409m.exe then skins409m.exe) and follow the on-screen instructions.
Please note that this add-on is impossible to install over stand alone Pacific Fighters.
Does anyone know how to get this game to run in vista?
[TW]Taggart;15017305 said:im running it on vista 64, all i needed to do is run it as admin.
altho not installed the 409 patch yet.
Hi guys
I want to know does the Ultrapack 2 runs on vanilla Sturmovik 1946 or should I buy the Complete version from Amazon UK in order to run the Ultrapack?
Thanks first!
Pete
