- 17 Jun 2012
Yes. Pay more for less increase in performance, they really are winning at the minute.
Stick with what you've got and wait for a worthwhile upgrade.
You've very possibly made me sad! I'm going to have to check on this tonight when I get home and see if I've been half utilising my card forever.I'd have thought you would absolutely be aware of what games use crossfire and which games don't. Usually you get an on screen display in the top right hand corner that says AMD Crossfire Technology when the game is running in crossfire. You also usually need to manually enable crossfire in your driver settings for it to work. If you haven't had to mess around with driver settings or seen the AMD Crossfire in the top corner of your screen when playing games, then the chances are you haven't had it enabled, possibly ever?!
Except in VR the 1070 or 1080 will be a huge upgrade over what he has. It would be worth it if VR is his main point of upgrading now.
For the limited amount of games around at the moment that do actually support VR (directly or indirectly), and given that some of the games I play doesn't, is it worth up(or side)grading at all given what card I'm already running which pretty much does what I need it to when outside of VR.
Going rate by ended auctions is about £470, so about £420 ish after fees, not sure if Gumtree is where the numpties shop but it seems someone massively over paid for that.
The card does what he wants aside from VR. Sure he could spend some money for the sake of it but I don't see the point if it's all working properly.
you would have to be a carrot to stick with the 295x2 IMO.
I'll try not to take offence to that![]()
your telling me it's the smart move to say no to £500?
No. I was telling you that I'll try no to take offence to you suggesting I'm a carrot![]()
that is only the case if after you have heard all the advice above and still decided to keep the card. what other reason would there be to keep the card?
so which one is it? are you keeping or selling?
The majority of advice is telling him to keep the card.
And if he decides to do that fair play to him. He has a card that he is very happy with, no point in changing just for the sake of it.
Keep your "carrot" comments to yourself.
Unfortunately there isn't really anything to upgrade too from a 295x2 on amds side when you take into account when crossfire works. Heck a gtx 1080 won't be a whole lot faster when crossfire works.... the only card that will handily annihilate it is the 1080 Ti
the majority of advice isn't taking into account the new info i provided above. based on that do you think he should keep the card?
Well look on the bright side, if you haven't had crossfire enabled that you've just gained a significant upgrade! Well, in theory anyway - the problem is so few games work with crossfire so the smart choice would be to go with a single card that will guarantee the crossfire level of performance. Vega 64, 1080 or 1080Ti would all do that...You've very possibly made me sad! I'm going to have to check on this tonight when I get home and see if I've been half utilising my card forever.
