- 27 Apr 2004
- In bed with your sister
Got home yesterday so decided to sort out the farm a bit after the usual failures while I was away at work. I'm back up and running at a reduced capacity due to temperature issues - both PC and environmental.
Switched the two i7s back on in the computer room and within an hour, both were running at 86 degrees and the heat was unbearable - must've been over 30 in the room I couldn't bear to be in there. The media rig in the living room is still faithfully churning out A3s. There's no way the bedroom rig is going back on this side of October
I'm now running the Photos machine at stock and the gaming rig is only running 2 GPU clients on the GTX295 while the heatwave lasts. Supposed to be a lot cooler from tomorrow so I might switch the SMP client back on on the gaming rig and see how that works out.
HFM currently reporting ~36k ppd on the reduced capacity - that'll do for now.
