iCraig said:
Like I said, I can get a 7600GT for £100. Which I've been told is way better than the 6800GT etc, so it's worth the extra 20-30 pound.
It's not £140! Is the £8 delivery figure made up or something? This competitor is free delivery for items over £80. You can't add delivery costs etc into an argument about saving money, as it's subjective to where you buy it from. You've just picked one figure to go by. It can be bought cheaper elsewhere. £105 is the lowest I've found so far. £35 less.
i would check the stock on those places as everywhere im looking that sells the AGP version for less than OCUK seems to be sold out. the £8 delivery fee was me presuming you were buying from OCUK.
iCraig said:
So the X800XT is as good as the 7600GT in terms of performance? Even so, is it worth £20 extra to have a brand new one, rather than a second hand card that has probably been clocked, modded and used a fair bit etc. Buying new also removes the hassle of finding a seller in the first place, making sure he is genuine etc etc. For a few hundred yes, but £20 isn't a lot of money for piece of mind and convenience.
with a £20 difference if you can actually get ahold of one, the 7600GT is a better option than a second hand X800XT.
iCraig said:
All I'm after is a quick upgrade to see me through one game at medium settings. The 7600GT will do that.
depending on the resolution there are very few games that cant be played at full settings with a 7600GT.
iCraig said:
True, but most of that will involve selling this PC and locating and buying second hand parts. I work from my PC each day and having it in pieces across the floor, juggling components and buying new ones from MM means I could be without a PC for several days. Not good. Don't forget, I'm only buying this graphics card to see me through one game. I don't need socket 939 or a new CPU for that really. My line of work doesn't require it either. If I played more games, or needed a faster PC overall, I wouldn't of bothered asking here, I would have gone with the new PC option.
I can see your point without you having to be condescending.
sourcing parts really isnt that difficult... using a Wanted Advert and OCUK shop it took me 7 days to go from:
XP2800
512mb ram
radeon 9800pro
generic PSU
skt7 mobo
generic case
to
AMD A3000+ (currently an opteron 148 @ 2.9Ghz bought from MM for £65 worth £75)
asrock dual 939 board
X800GTO2 (now an X1900XT 512mb crossfire master)
1 gig ram (now 2 gig XMS bought from MM for £95 worth £140)
Antec super LAnboy
Akasa 400 watt psu.
and to enable myself to continue using my pc i simply didnt fit all the new stuff untill i had it all there in front of me, took about 6 hours and i had a brand new system and listed the old kit on members market. as for finding "trust worthy people" on members market, thats what the trust system is for, all this is only as difficult as you make it
whilst i will admitt that if you can get a 7600GT on AGP for £100 that it is a better option, its still a bad deal, bad value for money compaired to PCI-E offerings and a negative investment. that said, if you do buy it then i genuinely hope that you are happy with it and that it serves you well for the next 12 months
p.s. ... condescending... that wasnt my intention, very sorry
