I built myself a new system as my P4 3.4 Skt478 was getting very long in the tooth. My new system I purchased from where I work (I build computers but am not too knowledgable when it comes to overclocking etc)
Antec 1200 case utilising all 120mm mounts with Antec tricool fans
Gigabyte GA-MA790FXT-UD5P motherboard (with latest bios)
AMD Phenom 955 3.2GHz CPU
Corsair H50 cooler with antec tricool fans in "push/pull" configuration
8GB Corsair "Dominator" ram
Crossfired XFX 1gb OC Radeon 4890s
WD Velociraptor 150gig 2.5'' HDD
Corsair HX750 PSU
1X Sony DVD-RW
My newest edition is the H50, but I am dissapointed with its cooling abilities, it doesnt seem that much better than the stock AMD cooler except when it is idling in windows, soon as its under load the temp goes sky high. I tried to clock the system up using the AMD clocking utility and the system got to 3.6ghz at which time it reached its thermal limit at 62'c and rebooted the system.
The system is in tip top order, I have dusted out all the fans, system etc, removed the stock thermal paste from the H50 base and the cpu and applied antec silver paste evenly. I have made sure the pump is the wrong way up as apparently this helps the flow. Both push/pull fans are set at same speed and full speed at that.
Once I have sorted the H50 cooling issue Im hoping to OC the graphics cards, ram etc but from what I have been reading there is quite a bit of negativity about the H50, and the H70 is out now.
Opinions, thoughts and advice most welcome.
Al
Corsair HX750 PSU
1X Sony DVD-RW
Al
