Caporegime
- 8 Jan 2004
- Rutland
ichabod crane said:looks good although im not keane on the swiftech radiators... but ive heard there perform ok... have you thought about a D5 pump they are very good... £10's worth of tubing will get you just over 6ft of tygon hose so measure twice cut ones
6 foot should probably be enough, it was slightly more than I needed in my Coolermaster Stacker, which is about as big as cases get.
I don't have any complaints about the Swiftech Rad, works perfectly even with 2x120mm fans at 5Vs and totally silent. At stock my system idles around 20 degrees and hits about 25-28 load. Overclocked I rarely see mid 30s.
