I've just swapped the contents of one pc into another case. Everything was working fine before this, but when i go to turn it on in the new case there is no output to the monitor. All the fans are blowin and the green light is on on the mobo. I've tried changing between cpu's and tried the ram in different slots and also with single sticks. I cannot however try a different gpu as this is the only pci-e one i have atm, other cards that are kicking around are agp so no use. I've even tried 2 monitors the dell one just does nowt and switches back to the amber light if i try turning it on, however when i unplug the cable from the pc it tells me no signal. The other monitor just tells me no signal whether its plugged or not and goes into stand-by.
Any ideas guys? I'm all out.
Specs as follows
CPU : tried E6300, E6600, and socket 775 Celeron.
Ram : GSKILL DDR2800 6400 NR
PSU : Hiper Type-R580W
Mobo : P5W DH Deluxe
Edit - tried clearing the cmos also via jumpers and removing the battery.
Specs as follows
