Built my new system today and it works which is nice.
Unfortunately ocuk decided to send me windows home server instead of the 64bit vista H.P. which i asked for. In a desperate attempt to use my new pc i decided to install home server before sending the discs back (tomorrow morning) to get my vista. It worked ok except i couldnt get my native monitor resolution so i stuck *** gfx driver disc in. Chose to install the XP drivers as i thought home server was based on xp. Rebooted and now all i get after windows load is a fuzzy screen of mush.
Q: how do i sort it out? I guess a windows re install might do the job but cant seem to find out how to do this.
p35-ds3p
q6600
8800gtx
Cheers.
Chris
p35-ds3p
q6600
8800gtx
Cheers.
Chris
