imac and photo editing
7 Jan 2003
Leicester
one of my customers is well into photography and says the iMacs are not a good screen for photo editing versus his Dell 2020 i think it is.
Ive always found the iMac screens look really clear.
what do you guys use and why>
thanks
iMacs have good quality Samsung/LG IPS panels in them. I've always found them nice to work on and aren't too far off from proper calibrated settings out of the box.
yes thats my point ,i love them but this guy really thinks the opposite,i think he's just anti apple.best screen I've ever had anyway,glad you guys agree,ill show him this thread lol
Does this customer always wear rose tinted glasses as well? ;)
About a year and a half before I got my iMac in 2012 I bought a 24" IPS Monitor made by HP. It's a stunning piece of kit and set me back £340 at the time. Which, a lot can agree that £340 is a lot for a monitor.
When I had this, any other monitor was just terrible in comparison.
Put it this way, that monitor doesn't even compare to the screen in the iMac. :)
The iMac has much better blacks, truely beautiful colours throughout and the 27" runs in a 4k resolution as well (it's either 4k or not far from it)
The Dell won't even touch it.
While I hate my iMac at work and much prefer Windows there is no doubt that screen quality on them is pretty much the best there is.
Has he messed around with the screen preferences at all?
iMacs have good screens, however I hope you haven't been caught up in the hype of "you must use a Mac to do photography/graphic design work" that I see people spouting off so much.
Phate, your iMac display isn't 4K or even near it, the 27" ones have a display resolution of 2560x1440, which is far off 4K. It's actually half the pixels of a 4K monitor.
That specific Dell monitor won't touch it, sure however the panel used in the 27" iMacs are also used in Dell's 27" monitors amongst other monitors (I have 4 monitors that use the same panels).
It is really clear...why? Because I have 2 and they are both clear.
That's not why they are clear, they are clear because they tend not to use any anti-glare coatings and have a glass front to them, which results in higher clarity as the anti-glare coating isn't diffusing the light from the monitor and smearing the pixel sharpness a bit.
Aha :D - I don't know the exact resolution of 4k but I remember playing a 4k video on the iMac and it filling the screen.
My baaaad. Ignore that line of hogwash from my post :D
I'm sure you've played plenty of 540p and 720p videos that filled the screen too... :p
Brain fart!
I wouldn't know anything of the sort. ;)
That's another benefit, glass front for easy wipe/cleaning....ehem...
In all seriousness though, the glass has been great for me on my displays (not iMacs but they use the same panels with tempered glass).
You can use harsh chemicals on them to clear any crap off, which came in very useful when I had to clean gloss black lacquer paint from my monitors.
I didn't actually say why they are clear, I just said I have 2 and they are both clear.
It's like saying I have 2 pair of Jeans and they are both blue...:p
Personally i think they're great. I have a second monitor which is a LG 27EA83 which has something ridiculous like a 98-99% Adobe RGB gamut. I find the iMac to be better and my main monitor!
It may very well be he's talking about the gloss/shiny finish on Apple displays. It makes things look great but has its downfalls.
Firstly reflections, which can be mitigated by using them in darker rooms with no direct exposure to either daylight (ie not facing a window) or lights.
Second, the same thing that makes everything look so nice on the screens is also the biggest problem. Glossy screens give an artificial lift to contrast and colour. What may look great on a glossy screen but flat when printed. This is why most/all professional screens marketed at the creative industry have either a Matt or satin/lustre.
The iMac screens use the same high quality IPS screens as many other higher end monitors (Dell 2713 for example) but sticks a piece of glass in front of it so it's no better or worse than its well priced compatriots, other than the gloss issue. Unfortunately the gloss issue is one of the main reasons I'm always deciding against an iMac.
On the other hand I doubt a cheap Dell all in one will have a screen remotely comparable to the iMacs, even with the gloss issue...
So what monitor not IMac would be ideal for editing?
Dell 2713 (either version), the Samsung 950 PLS display and a number of others. If you want to get silly there ar e plenty of professional monitors you can buy for £1k + as well. At the 27" size you're looking at at least £500 for a good one.
It's not at least £500 at all for a good 27" 2560x1440 monitor. You can get displays that use the iMac panels for less than half of that.
