Heres a choice
After adding the 16gb and 512gb storage price for the m2 air is £1649
I look at the MacBook Pro 14" which has M1 pro and 16gb/512gb SSD as standard for £1899
Now that larger display is quite tempting, and as portability is not my highest priority, Im wondering if I should just go for that, would do you think, m2 vs m1 pro?? would the M2 air be better future proofed for updates?
Yes absolutely. With the base M1 Pro (6P, 2E) you get 6 performance cores (versus 4 on M2). And you get a bigger GPU. You also get a bigger battery and a much brighter, sharper MiniLED display with proper HDR that's miles better than the Air's.
I thought the battery life is not quite as long vs the air?
I presume there will be a refresh soon on the pros though, perhaps to an M2 chip, but that may bring a price hike.
Yes get the Pro. Don't forget HDMI & SD-Card slot as well as what's been mentioned.
I use the OcUK ones, they last well although probably quite expensive compared to others.Can anyone spec me a good quality surface mat for my Logitech mx3 mouse, needs to be big enough for my MacBook to sit on it as well.
Yeah they do different sizes.I have an ocuk branded one but want a smaller one, as the one I have is quite big, was fine for my iMac and other accessories. It’s wearing a lot at the edges now.
Will see if they do a smaller mat.
Yes. Make sure you don’t have the box ticked in energy saver setting to prevent sleep when the screen is blanked.Does the hot corner put display to sleep eventually put the system into sleep as well?
I never noticed any memory related issues with my M1 Air, however I did notice improvements with responsiveness when I moved to a 14" Pro, which could either be the CPU or the fact I now have more memory.
