Images of items I have purchased (except trainers)
Man of Honour
20 Sep 2006
Both going in the roof, but even with them in place there's still lots of room for more rads if needed? Fully removable motherboard tray, etc.. really nice case.
I've got 2 x 200mm fans in the front as well :cool:
My only concern is if it's wider then my feet might hit it as my case is under my desk. Edit. Actually, I had to put my Enthoo facing forwards instead of sideways due to my monitor stand. I can put this at the back and sideways like I used to have my case which I think may work. need to measure it though! Edit again, measured and it's a no go. Damn.
I don't think I need more rads, only cooling my CPU and GPU.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
I don't know whether RAM was the direct cause, but when I ran my iMac with 24 GB (Apple's own 8GB and a Crucial 16GB kit) it used to sometimes refuse to wake from sleep and eventually restart. Not long before I sold it I took out Apple's 8GB and it seemed to cure the issue. It could have been coincidental, but something worth keeping in mind.
Thanks, I'll keep an eye on it. The iMac arrived today, but it has a faulty fan so it sounds bad when on lowest idle RPM. Advance replacement has been approved so just need to live with the noisy fan until the new one turns up.
31 Jan 2004
Matakana New Zealand
Thought it was time i replaced my ageing QC25's, after deliberating the QC35ii's and the WH-1000XM3's, there was only ever going to be one choice, scored a bit of a bargain too as the box was damaged, everything inside was still perfect though, so got $100 off them, $400 instead of $500 (About £200)
14 Jul 2005
Bristol
https://live.staticflickr.com/65535/48134692642_9e698f6f3c_b_d.jpg
https://live.staticflickr.com/65535/48134689912_29afbf1106_b_d.jpg
You can't go wrong with them IMO, good choice, I really like mine. I found the XM3s to fit better and be more comfy than the QC35ii and the sound was, personally nicer on the XM3s, especially as I could have them at a lower volume than the QCs which is always a bonus.
