lol first thing I thought was "there goes his shins!"Goodbye shins
Ah but I do like them, super quick and conveineint, only boils the water needed for the size of cup you dial in, and in this day and age, efficiency is important. This is my third one - Living in a super hard water area means even with a brita filter, limescale builds up inside them so every few years I need to replace it.
Plus a normal kettle accumulates limescale gunk so you don't want to just boil a cup of water in a normal kettle anyway as you will be pouring in limescale too
You don't get the limescale depositing in the cup though that's the point, the internals that you can't access/see seem to get affected over time though but that's purely down to this hard water areas. A compromise for every few years, otherwise the machine itself works very well and is used tens of times a day.But you said that the Breville needs replaced every few years because of limescale so what's the difference?
No bueno. A kettle doesn't have the same issue. False economy. Inverse M3.You don't get the limescale depositing in the cup though that's the point, the internals that you can't access/see seem to get affected over time though but that's purely down to this hard water areas. A compromise for every few years, otherwise the machine itself works very well and is used tens of times a day.
I’ve had 2 - on 2nd now and it’s been 2 years and hundreds of cups and it’s still fine. The first one was going strong too but got rid as I wanted adjustable cup size. They’re more efficient I agree with mrk.Those one cup kettles are awful in regards to durability, I had two and they both died in quick succession.
