Imaging a drive
12 Dec 2006
Someone in the family got a new laptop. No windows media disks with it. Its all on the disk and no option to make recovery disks from it.
I want to make an image of the disk so if I have a problem with it in the future I'll be able to put in a new disk (or SSD) and put it back to its original state.
Can I use macrium reflect to do this. Do I need to remove the drive out of the laptop? Or can I image it from the laptop itself?
You can use Macrium reflect and you will be able to do this without touching the laptops hard drive, just you need a external drive to copy the image too.
Cheers. If I image a fresh install of Windows (most of the 500GB disk is empty). Will the space required on the destination be 500GB or less.
You can also use system image from within Windows 7/8/8.1 to an external drive. If using system image, the image will only take up the used amount of space, not the full 500Gb - I'd imagine that it's the same in Macrum Reflect.
