IMC or memory problem
23 Jul 2022
Dorchester UK
I have 64gb of 8 pack DDR4 3600 memory and used to be able to run it 4000 with very tight timings, gradually over time I have had to drop the speed to 3800 then 3600 using the same timings. My 10980XE is getting a bit long in the tooth, and I am wondering which is the more likely culprit, IMC or the RAM?
Probably IMC but hard to tell without testing the RAM in another machine.
Could be anything including voltage regulation or oxidation of the motherboard.
Send a tweet to Buildzoid with your question and let us know what he says.
I think its the IMC too, there must be a reason why they give lifetime warranty for RAM. My 5900x is playing up at XMP now. Can't wait for the new chips to come out.
1.2V not particularly high.
There are also the VDDG and VDDP voltages on AMD (not sure what the Intel equivalent is) that often get pushed up extremely high by the motherboard when using XMP/manually overclocking.
Rather than start a new thread, thought I would give this one a bit of a jolt.
Updated my BIOS a while back and finally got to overclocking and testing stability on the CPU, out of curiosity I played a little with memory speeds a week or so ago. Bumped up the speed to 3800mHz and with my current settings it is totally stable, with the old BIOS and voltages it would randomly crash or not boot at all. When I feel the urge, will play around with timings and see if I can get 4000mHz again.
