I need to purchase a set of impact sockets for my Snap On as the ordinary wrench sockets like draper seem to round the nut very easily as they never seem to be a good tight fit whether its to do with their cheapness or the number of sides in the socket itself.
I don't want to spend a fortune if I have to even though I forked out on the snap on but can anyone recommend a top quality set or I'm I better off buying a snap on set or Britool set at £120+.
There could be a set out there which is just as good at half the money if you know what I mean.
Cheers.
Cheers.
