Improve WInAMP sound quality without "plugins"
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
I found whilst snooping the latest version of Winamp (upgraded recently) that some questionable features are enabled by default.
So I changed them to standard settings and disabled the limiter and after a reload found music had a bit more depth, more clearer.
Background ambience such as Vocals etc are much more audible now.
Give it a shot!
Must admit it has made some difference. I'll have to play through a few tracks before I probably really notice a difference. But thanks :)
You probably won't hear much diff on all tracks, only certain types of music styles through each genre - I found the most difference where there are background vocals and softer instruments :)
Seems a bit wierd but after changing them options after I restart my computer, winamp is reset, default colours for the skin and incorrect on screen position :confused:
Humm cool, out of interest but what sort of music are you listening too?
Im giving this a go and just wondering what areas it might sound different....
Because I have no need for it. Xonar D2X has built in normaliser (if needed, whihc it's not) so all software processing set to off or standard if no off available - let the amp do the rest and the soundcard.
You folks seem to have a bit of a misconception about replaygain. I suggest you read about it.
It's a good thing, it doesn't normalize the sound of files in order that all quiet parts sound the same loudness as the loud parts, it makes the average percieved loudness the same as the other files in your collection.
For example the replaygain tag on the mp3 file I've got playing right now (Nivarna, Lithium) is -4.70 dB, meaning that when the player comes to play it it will make the song 4.7db quieter.
However, a track of NIN's Ghosts I-IV has a replaygain value of -4.10 dB, making the song 4.7db quieter than it's actual recording volume when played.
This allows all the songs in the collection to sound the same volume, a good thing, as you don't want to be constantly adjusting the volume of your system.
Replaygain does not, I repeat does not, negatively impact sound quality, unless for some reason you like your collection having dramatically different volumes (NOT the same as dynamic range, or "the loudness wars" that people bat on about)
http://en.wikipedia.org/wiki/Replay_Gain read here if you don't believe me.
Otherwise your settings are generally sound, I'd keep "allow 24-bit on" as I have some 24-Bit FLAC files, and I'd just turn EQ off completely. I've no idea how EQ works in winamp so that may be what that setting allows.
And leave replaygain on unless you like adjusting the volume all the time. But heck unless you've applied replaygain having it turned on won't do anything!
