- 14 Jul 2005
- Birmingham
Hi all,
I currently have a Worcester Bosch Greenstar 25Si combi boiler located in the kitchen with a wireless Drayton Digistat thermostat wall mounted in the hallway. All rads except the bathroom towel rail have a Danfoss TRV.
The boiler with its rotary manual timer:
The Drayton thermostat (no programmable functionality):
The wireless receiver unit which seems to be wired into the boiler:
The TRVs:
I would like new TRVs anyway, as the current ones are stiff, yellowed, and covered in paint splashes. I could go for smart TRVs to give me some zonal control.
I would also like a Google Nest thermostat or similar to replace the existing controls.
I want to DIY this if possible.
Any advice on what I need to do, compatibility issues, would be appreciated.
The TRVs:
