- 14 Jul 2005
- Birmingham
Thanks, really helpful. Do you wire in the 'normal' 230V switched live as well as the EMS connections, or only the EMS connections?Assuming yours is similar to mine, the TADO app wizard is very detailed, it gets you to power off, it takes you through taking the front panel off, dropping the control section down etc, where to route the cable, how to connect.. Fairly easy.
It's absolutely fine to take the front cover off IMO, the Worcester Bosch is really well designed for service, the control panel is hinged so it all comes down and is easy to access. I don't think TADO would offer the installation guide in the App if it wasn't appropriate.
Do you know if I can access the app instructions for my boiler model without purchasing the device to see what it says?
