My first post, so hello everyone
So i got a question, has anyone got any suggestions in how to improve airflow inside my Cooler Master Wavemaster? I like the look of the case and everything but the airflow is utterly crap. I've added a 80mm fan in the top of the case but that hasen;t really given much of temp drop. My systems specs:
E6300
7900GTO
Type-R 580W
Gigabyte DS3
Geil 6400 1Gb
Two wester digital 250GB hdd's
And I'm using the Scythe Mine cooler.
My idle temps in core temp is around 48C on each core, which i think is wuiet high. As soon as i take the side panel of my case the temps drop drastically. I get around 36C on each core once the panel is off. Im thinking about going to water cooling but theres not that much space in the wavemaster. If anyone has any suggestions what radiator i could fit in there without doing any major cutting then please suggest away
I got the case fans and CPU fan running at full speed and my comp sounds like its gonna take off.
Thanks,
Martin
E6300
7900GTO
Type-R 580W
Gigabyte DS3
Geil 6400 1Gb
I got the case fans and CPU fan running at full speed and my comp sounds like its gonna take off.Thanks,
Martin
