In case screen
8 Apr 2009
Manchester
Do any of you guys have a screen inside your case and if so which one do you use?
Are they useful I know they look cool, I'm thinking of adding one, is it worth it
My Corsair 780t is going strong don't really want to upgrade the case
I just got a 5" screen from amazon or ebay, fairly generic and run Aida64 on it.
Is it worth it is a hard question. If you like to monitor stuff, particularly whilst gaming, then yes is good. It does look cool too.
You can use any old android devices
You have lying around
I have used phones,7 inch tablet, 10 inch tablets
Currently using an old lenovo yoga tablet
One of my favourites as can also use it as external display
As its got a great metal kickstand built into it
It's something like android 6
But still works fine for this
Aida64 you can do good sensor panels
But it's time consuming to make them
In the past I used a free app
Forgot the name now something like pitikapp
Much simpler to use you can make a basic sensor panel
In a minute
Might not look as nice as an Aida64 one
But it still does the job of showing temperatures, fan speed etc
And very simple to use
My desk isn't big enough to have my case on my desk, unfortunately. It's a very nice case too, so would be nice to look at it.
But it's certainly something I'd probably do if it was and I had a bit of spare time.
Maybe just to have a video or someone looking like they're trapped inside the case for my enjoyment.
The entire front of my case is a screen :).
s!Ahf7xhLzGq1QsTb2aaOXITJrwokp
It runs a custom skin using AIDA64 to show system stats but you don't have to stop there - get Wallpaper Engine from Steam (£3.49) and have it run an animated wallpaper of your choosing of which there are thousands or make your own. I've also had it display the doorbell camera, share prices, live SpaceX launch, news etc. Anything you want to keep an eye on while your main PC screen is busy is possible.
It's incredibly useful and I don't know why more case manufacturers don't have it as a feature instead of the boring fronts we have now.
Just set up pitikapp on an old phone after reading this thread. thanks for the heads up, really straight forward, didn't know it was a thing.
You're very welcome
Might not look as good as aida64
But it's much easier
And of course it's free too :)
For videos or animations
As I mentioned lively wallpaper
And a software called spacedesk
Basically turns your Android into another monitor
Then you can tell lively wallpaper to only show on that device
Or can tell it to display on all devices
And have an animated/video desktop wallpaper
Which is matched on the Android device
And again both free software :)
Have the phantek one for my nv9, just got Wallpaper Engine to try will setup adia64 at some time.
They have a screen for it now?
Always thought it should have one
Above the motherboard
Aida64 if you have a screen that's a common resolution
It's much easier/faster
If you use an already made sensor panel
That people have shared
Then modify it
That actually looks great
What case is that?
And did it need a dremel to get the screen in?
Ooooooh do show
I feel a Xmas present for myself coming along :cry:
Had loads of phanteks cases
Starting way back with the primo
Before most people heard of phanteks
You need to show pictures
Very interested if it still leaves space
To get a radiator and fans above it
I do have the artic freezer 3 420 mm up top, will do some pics when I've got time.
