In need of a new case
29 Jan 2019
Hey guys, so i have abit of an issue that means i need a new case for my pc.
I have just bought a gigabyte rx6800 xt and it does not fot my corsair 220t, because i have to mount my radiator on the front, as the ram stops me top mounting.
I am torn between the lian li lancool 2 mesh or the corsair 4000d, has anyone used any of these cases before?
Can i use my corsair sp fans on the lian case? And how dark actualy is the side panel on the black 4000d?
Thanks
I've got the 5000d airflow and can't fault it, Radiator was mounted in the front for a while, I've since moved it to the top.
Thanks guys, i think im in desperate need fot a case now :cry::cry:
hitting temps of 80 to 90 degrees,
Has ypur gpu tenps dropped much with it being top mounted?
AIO RAD Top mounted or Side would be same around temps of the CPU
Having the AIO RAD top celling of case be better that way can have 2 fans blow air in from front , One below the GPU
If you can somehow off-set the rad at the top to miss the memory sticks be great :)
Low profile memory / Or 15mm thickness fan could help
looking at that photo, If you got the AIO Corsair fans blowing inwards in the Rad at front making heat in the case will not help the GPU Temps.
A: Can i use my corsair sp fans on the lian case?
Yes if you transfer the ARGB/fan hub of corsair Over to the Lian case
them SP corsair fans made for the Corsair control hubs to work the RGB
Trouble is that corsair Hub shows the bear circuit board & made for the 220t & fitted , you would have to purchase a fan/argb corsair hub on its own
new Corsair AIO kits come with a Control hub for the fans & ARGB of there own
Can buy Corsair fans Packs like SP & other fans with hub
Thanks
Corsair 220t got 2 rows of Rad/fan holes on top if you had a 240mm Rad AIO you would mount it close to the tamp glass panel.
I take it you got a 280mm AIO?
If you got this then you only need to use the corsair hub that come with it for the case fans & the 2 for the Rad
or
I paid £100 for the corsair-hydro-series-icue-h100i-elite-capellix 240mm bottom link
By looks of your photo your using an older Corsair AIO ?
I have the h100i
or
I have the h100i rgb platinum 240mm with the corsair vengeance rgb ram, the ram sticks are too tall to let me top mount.
So the fans pulling air on through the rad, is that not correct?
Best to have 2 fans on Rad mounted as Exhaust blowing warm air from the rad out of the case :)
if you got a 280mm corsair AIO then that will make mounting on the celling of the case harder to clear the memory , 240mm you should not have much trouble, had the 220t some time ago with 240mm mounted on top ,cleared the memory ok, that with the corsair RGB Pro memory.
I thought it was the 240mm i had but tried to mount on top last night again and realised its actually a 280mm. So im now looking at the lian 011 dynamic mini
Ah then ,Yes indeed a new case you need 280mm in that case a bad move,
lian 011 dynamic mini just purchased myself :)
