Hi Guys
As you may be aware, In Win have been causing a stir recently with their excellent ultra high end case offerings.
Their latest model, the TOU is a futuristic design that is truly unique.
Showcased heavily at every major event this year, the TOU is the premium case to have.
There is nothing on the planet more unique than this case.
Available to pre order now with stock due soon
Grab yours now!
In-Win Tou Tower Design - Transparent @ £695.99 inc VAT
InWins Tou with 3mm Tempered Glass and Touch Control panel and Two speed fan controller, InWin keep pushing the forfront of case design with there new case the InWin Tou.
Features:-
- Special Transparent Coated Glass and Aluminum Frame
- 3mm Tempered Glass
- Once Powered off the tou will function as a mirror
- When the system is on the light passes through the glass
Specification:-
- Dimensions: 258 x 585 x 645 mm (W x H x D)
- Material: Aluminum (Body), tempered glass (exterior)
- Lighting: Blue (can be deactivated, 5 steps)
- Form Factor: ATX, Micro-ATX
- Maximum video card length: 360 mm
- Maximum PSU length: 220 mm
- Power Supply: Standard ATX 1x (optional)
- Expansion Slots: 7
Fan:
- 1x 120mm (front)
- 3x 120 mm (cover)
- Radiator Mountings (partial waiving fan):
- 1x max. 360/280 mm (lid, optional)
Drive Bays:
- 1x 5.25 inch (external)
- 3x 3.5 inch (internal)
- 2 x 2.5 inch (internal)
I / O Panel:
- 2x USB 3.0
- 1x each Audio In / Out
Touch Panel:
- 2x LED Switch
- 1x fan controller
- 1x Power Switch
Only £695.99 inc VAT.
ORDER NOW
Grab yours now!
Features:-
Specification:-
Fan:
- 1x 120mm (front)
- 3x 120 mm (cover)
Drive Bays:
I / O Panel:
- 2x USB 3.0
Touch Panel:
- 2x LED Switch
- 1x fan controller
- 1x Power Switch
ORDER NOW
