Increase Wireless Network range up to 1 mile.
7 Sep 2008
hi all
is there a way to increase my wireless network range of up to 1 mile?
someone was telling me they used their sky dish to increase the range something about a parabolic effect, usb cable and usb dongle. also a big wok was mentioned.
is it true?how can it work?
Wireless point to point bridge links can extend upto ~26 miles @ a data rate of 11Mbps using a 21dbi dish antenna and ideal weather conditions.
This is achieved by using a more focussed beam width rather than scattering the signal like an omni antenna.
yeah it can be done google and you will find mods like this http://flakey.info/antenna/waveguide/ allowing extended range thought dont expect massive speeds.
this sort of thing will need a fairly direct line of sight as well.
would be possible to do it using more routers as repeaters but this is impractical
does it have to be done over wireless?
Thanks yes it has to be wireless because of the distance.
Direct line of sight mmmmmm
wow 26 miles
just like the Flora London marathon
What's the purpose of this out of interest?
As if it were for anything serious I'd be looking at real 5Ghz bridges (not a bloody saucepan with a pringle tube glued to it) and some big parabolic grid antennas.
TBH though if I had clear LOS I would also be looking at freespace optics and the likes.
The point you've missed is a parabolic antenna simply focuses the signal, provided the angles are correct the £2 saucepan does the same job a £200 antenna you can buy does, it's basic physics but hey, if you're "serious" and want to spend for nice looks that's your prerogative. I have to admit though, using a pair of old sky dishes would be more effective. 5GHz does not automatically mean it's better than 2.4GHz either.
Optics are overkills tbh, not to mention requiring an uninterrupted los, wifi will handle the odd bird more effectively.
lol
I think I'll try the pringle method first
then I will move on to my sky dish
the point to this? So I can connect to my friends wireless network
