Hi there
Guys got some great monitor deals for you so check out these:-
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £114.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 3 Years On-Site
Only £114.99 inc VAT.
ORDER NOW
Iiyama ProLite E2208HDD 22" Widescreen LCD Monitor - Black @ £110.44 inc VAT
The ProLite E2208HDD Widescreen LCD features true High Definition, 16:9, 1920 x 1080 pixels as its native resolution. Impressive colour reproduction is achieved with a typical contrast ratio of 1000:1 with the User Option to enhance further with Advanced Contrast Ratio enabled for 10000:1. 'Opticolour' automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity.
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- VESA Compliant
- Dimensions: 516.5mm x 386.0mm x 193.0mm
- Weight: 4.2kg
Only £110.44 inc VAT.
ORDER NOW
LG E2240T 22" Widescreen LED Monitor - Black @ £129.99 inc VAT
LG’s new LED LCD Monitor employs LED backlight panels that displays incomparably clearer pictures than CCFL panels and its mega contrast ratio of 5000000:1 and Full HD resolution makes sure that you get clarity beyond comparision. LED is an Eco-friendly technology that does not use any halogen or mercury and moreover, it saves energy consumption by more than 45%
Features
- LED Backlit
- Screen Size: 21.5" Widescreen
- Dimensions: 529.8 x 410.3 x 202
- Weight: 2.8kg
Only £129.99 inc VAT.
ORDER NOW
Acer H233HEbmid 23" Widescreen LCD Monitor - Glossy Black @ £135.11 inc VAT
The Acer H233H is a 16:9 format display that renders full high-definition video and audio performance for a powerful media and cinematic experience.
This 23" LCD is the perfect choice for advanced 1080p Full HD gaming and multimedia applications. Enjoy action-packed moving images with a 2 ms response rate and 80000:1 contrast ratio , ensuring crisp and razor-sharp image quality.
Features:-
- Screen Size: 23" Widescreen
- Contrast Ratio: 80,000:1
- Response Time: 2ms
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions (WxDxH) - 561.6 MM x 177.5 MM x 393.9 MM
- HDCP Compliant
- Stereo Speaker
- Weight: 5.3kg
- Warranty: 2 Years On-Site
Only £135.11 inc VAT.
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £164.49 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Only £164.49 inc VAT.
ORDER NOW
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor - Black @ £164.49 inc VAT
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Contrast Ratio: 60000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
ORDER NOW
Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black @ £169.99 inc VAT
Film fans and gamers will love the Samsung SyncMaster P2450H TFT display! The Samsung P2450H is a 24 widescreen monitor that willplunge you into all your favourite films and 3D games with breathtakingly realisticresults. The P2450H has a fantastic contrastratio for deep blacks and rich colours. Plus, the P2450H has aresponse time of just 2 ms which is great for online games! Plus, the Samsung SyncMaster 2450H has a wide selectionof connections, including an HDMI port for hooking up a HD games console orcamcorder.
- Contrast Ratio: 70000:1
- VESA Compliant
- Dimensions: 578.0mm x 430.0mm x 190.0mm
- Weight: 5.4kg
Only £169.99 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £254.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 15000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
Only £254.99 inc VAT.
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 3.8kg
ORDER NOW
- VESA Compliant
- Weight: 4.2kg
ORDER NOW
Features
- LED Backlit
- Weight: 2.8kg
ORDER NOW
Features:-
- VESA Compliant
- HDCP Compliant
- Stereo Speaker
- Weight: 5.3kg
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 4.4kg
ORDER NOW
- Weight: 5.0kg
ORDER NOW
- VESA Compliant
- Weight: 5.4kg
ORDER NOW
- VESA Compliant
- Weight: 8.5kg
ORDER NOW
