Induction hob query
5 Aug 2013
Shropshire
Our induction hob is now 9 years old and I have noticed on a number of occasions that the touch controls don't work to the touch - We have to wipe controls with a cloth and also our fingers - Can anyone tell me if this happens on modern Induction hobs ? do you need bone dry fingers for them to work - Second question is bridge links to two sections to create a larger cooking area - One thing we have found is when using large pans sometimes a pan next to it isn't fully on the ring. Other than scratches and touch controls the Siemens has been fine.
One I am looking at is AEG HK654400FB - Our present one is Siemens - both 600mm square give or take - I need direct replacement as no room to go wider.
Never had that with our zanussi induction hob controls. They worked pretty well in all situations.
My Bosch does the same thing, needs to be dry or it will throw a wobbler. Only over the control section though, the rest of the hob can get wet and it still works fine.
Thanks both - that is interesting to know - I am tempted to change it just because it's old and technology must have moved on in 9 years. Also see that Zanussi do one with control knobs - just not sure about having those sitting up and ruining nice flat surface.
You'll probably find that due to the way capacitive touch works that even if you get a new one it still has issues with water on it.
I've got a year old AEG and it throws a wobbler if you get water on it, just quick wipe off and good to go. Only downside of induction unfortunately.
Yep my 2 yr old one with touch controls takes a wobble if water gets onto the controls.
Looks like I was panicking - Back to the drawing board - Neff do a point and twist removable knob which seem to be the answer but I bet that has it's drawbacks - Thanks for the feed back
The only thing I hate about my induction hob is that it pulses the heat (it’s a cheap Beko one) I’m not sure if they all do it, but it really does make it tricky it regulate a constant heat.
you are dead right ... that is their dirty secret, not described in product specifications - recent thread on it,
they don't have many power levels and just turn heat on and off - so simmering, with the precision of gas is out.
Is this true of all induction hobs? I was under the impression they use PWM to regulate power/heat and therefore no on-off switching like halogen. Hate that burning every 2 minutes cycle.
We have a NEFF with a magnetic removable "disc" works flawlessly... And as it comes off when not in use its kid friendly/proof too
Can't speak for all, but mine gives power for a few seconds then drops power off for a few seconds then repeat. The higher the power the longer the on power part of the cycle.
The thing looks great and is easy to keep clean etc, but I really do struggle with certain things. I find it hard to get my steaks right for example.
Once this one I've got is passed it's best I'm hoping the higher end ones have a better solution (they may already)
I came across the Neff one and this chef was saying the knobs don't last more than 6 month's - he said they are part plastic and new one is £40 - I really like the idea of the removable knob but now having second thoughts.
As regards pulsing I can't say I have heard or seen mine doing it - if boiling water there is no drop in bubbles rising as though it's pulsed off - I have a Siemens and it's 9 years old.
One thing I found out -do not put your Internet radio near induction hob - Mine let out a long dying scream and never worked since.
Like most things in life you usually get what you pay for.
simmering water is when you might notice it - boiling an egg ?
there is an extensive earlier induction thread ... I would email them to check how the new neff you reference works.
did not know - interesting reddit thread, raises reduce wasted heat, with induction, so lower ventilation needs for an open plan
Our NEFF disc/knob has lasted more than 6 months...But I can only compare our situation..But knowing how we don't look after things I'm surprised if they fail and ours is still gong...lol
Don't lose the knob, but if you have kids or pets, you can just drop it in a drawer to lock the hob. My inlaws have one of these and they haven't lost/broken it.
My Neff doesn't pulse, neither does anyone else's that I know of, although I often see this complaint from cheaper brands.
That's great to know, will be upgrading once this one breaks or I've had enough of it.
