ajgoodfellow said:They would be better suited to each other’s tasks really!
The P4 would be better in the server, the AMD in the games PC
The problem is that the AMD PC is lacking in ram - it could do with at least 1GB really
If you're considering an XBox 360 spend the money on a top end graphics card like a 7800/7900/X1800/X1900 and upgrade the ram to 2GB (in your AMD PC and make the P4 a server). This will give your PC a huge boost
The A64 3000+ is traditionally a great clocker so I'd consider clocking it too
m3csl2004 said:not if its 754 or an earlier 939
smit101 said:why not ask the OP then? and give him some advice,rather than being a winking smartarse.
