Yesterday I got the aforementioned Inno3d RTX 3090 from OCUK. Happy day.
Worked just fine under low load. Videos. Desktop. Browsing. Non intensive graphic games.
Cue cyberpunk 2077. Went up to 83 Degrees once at the start . Then it went back down. Fans working to cool stuff down.
Pink dots on the screen 1 sec and then No signal. Computer was still working. Had to manually turn it off and back on.
When trying to play. Same kind of crash except this time the computer rebooted by itself.
3rd time it happened I was unable to turn it back on. The computer turned on but the graphics card would show no signal (even though it looked as if it had power).
Turned it off. Left it for 5 minutes worked just fine under low load afterwards.
Edit : I could play for a while , the crashes just happen randomly. Also all the gaming ,browsing and testing was done on 2k resolution with max other settings.
Decided to get a benchmark test (Furmark) to see if that triggers it --- it did it within 5 seconds - pink dots into no signal.
At this time I was monitoring the temperature and it didn't even have time to reach 70 degrees.
Any ideas ?
My specs are i7-10700k , 2x WD Blue SN550 NVMe SSDs (500gb and 1tb) , 1x wd 1tb HDD , 32gb ram and a 850W Rog Thor PSU , 3 Case fans , the 120mm water cooler fan for the CPU. All this in a Fractal design Vector RS blackout case. MB is ASUS Z490-F
Mentioned so far: No damage. Has been reseated. Bios (not updated but changelog on asus website does not suggest anything to do with this problem). Airflow is at least reasonable. Different ports not checked (no DP cable). On different power lines (but same rail) on PSU.
Any ideas ?
