So im planning on doin a (my first ever)CPU loop in my freshly built cube.
Im not really one for cracking out a dremel,so one of my main ideas of mounting a Monsoon D5 res in the ODD bay is now dead(It would have badass tho
So what i want instead to to have a tube res mounted in the main chassis.
Id really like the res mounted via the top 4 vertical grommets between the front intakes and the Mobo.So when looking in it will look like its suspended there vertically.(I also know how i could fill a res mounted like this too )
Its hard to tell but i think it might be possible with some of these,,but im not sure,anyone shed some light?
YOUR BASKET
1 x PrimoChill 80mm AGB CTR System Phase II - Green £38.99
1 x XSPC Photon 170 Tube Reservoir £37.99
1 x Bitspower Z-Multi 80mm Water Tank £34.98
1 x Aqua Computer Aqualis ECO 100ml Reservoir £31.99
Total : £153.55 (includes shipping : £8.00).
For now im only setting up a CPU loop,not sure if i ever wanna invest the cash in GPU watercooling,as i tend to switch out GPU's often.
My loop order would be Res>pump>rad>Cpu block>Rez The pump would either be mounted at the front bottom of the case,or above the PSU.Im not 100% sure yet,i need to figure out the res first as it will affect what would be the lowest point of the loop.The rad would be a 240mm on the top
I have a last resort method of mounting an Ek pump/res combo the the front via the EK fan bracket thingy.Although i think that would be a little cluttered.
Pic of my current build,excuse the JJ.Abrahms levels of lens flare,i think my fone is on Acid or something
Prob doesnt help the angle i took it as is kinda crappy either lol
Any input welcome(and needed!)
)So what i want instead to to have a tube res mounted in the main chassis.
YOUR BASKET
Prob doesnt help the angle i took it as is kinda crappy either lol]
