Inside Sata slot expansion
4 Apr 2011
Hi guys!
I have a small problem, so I need some help.
I need a lot of data storage in my PC because of the high amount of movies ( 720p, 1080p, 3D... ), so I have 6 hard drives + 3D Blu-Ray RW + the SSD for system.
The main problem is, that I have a Corsair Obsidian 800D case with 6 HDD capacity, but the Asus P6TD-Deluxe Motherboard only has 6 Sata slots and I need at least 7 ( 7 or 8 if I can relocate the SSD to fit another HDD inside ).
Was thinking to buy a PCI card with 2 Sata slots, but don`t know wich one is compatible with my motherboard.
Please tell me wich one to buy to make sure that it will work with my PC:
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=49&subid=424
This maybe? http://www.overclockers.co.uk/showproduct.php?prodid=CC-004-SR&groupid=701&catid=49&subcat=424
Thanks
I would imagine they will both work fine.
But I can tell you that:
Startech 2 Port PCI Express Internal SATA II Controller Card
works on the ASUS P6T (your boards little bro) because I am using one in my streaming rig.
Both cards will be fine for regular HDDs.
I also use one of the above in my media server, I have 9 drives in it :( (full size blu ray rips are too big, 4k is gunna suck)
I would go with the above.
