- 10 Jul 2004
Ive just bought a Samsung 160gig 8mb cache SATA HDD , becuase my old IDE one is dying.
I went through all the aggro of backing everything up, then installed the new drive and removed the old. Booted from disc as Ive done 100 times (or something
) and installed all the peliminary windows stuff. The PC then reboots as normal, but instead of going to the next stage of windows installation it simply says operating system cannot be found. In the end I got fed up, reinstalled my IDE drive and decided to use the SATA for more disc space.
This worked fine, the PC can see the SATA drive, I formatted it via control panel and thought oh well there you go
Then this morning I get up , turn on my PC and get the same error loading operating system error. I think the IDE has finally died, and so spend some time ******* about with it, to no avail.
Eventually I try disconnecting the SATA, and suddenly all is well again!
So, my question is this, has the SATA got a fault? Or is it something else? Even when it wont load, it still registers in BIOS by the way.
Thanks for any help !
