- 20 May 2006
I have just installed a new Hiper Type R 580watt psu into my system, connected everything in my case and connected it to the mains.
When I flick the switch on the psu at the back I can see the switch is lit up red, so there is power being supplied, however when I press the button at the front of the system absolutely nothing happens.
I have checked all my connections, the main motherboard connector with the 4pin connector along side it is connected, both my hdd's are connected using the same cable and a extender, both my optical drives are connected the same way, my front and rear case fans are connected the same way, by then I had run out of extenders and so my window fan has its own cable.
Oh, before I go any further, I should say why I had to change the psu - my old unit shorted out with a white flash and a bang when I reconnected everything without first turning off the mains power.
Please help me oh wise ocuk pbb'ers!
, this is the second one to die as a result of my tinkering in the space of two months.
