- 10 Dec 2005
- England - Leicestershire
Hey,
I recently brought another 1GB module of Corsair RAM.
Previously I had: 2x 512MB Corsair TwinX Pro XMS DDR400 modules. With my recent purchase I now have:
1x 1024MB Corsair Value Select DDR400
The problem is that when I put the new 1GB stick in the system won't boot.
I have tested each stick in DIMM1 on its own and it works fine.
The 2x 512MB sticks work fine in dual channel.
The 1x 1GB stick works fine on its own.
The problem occurs when I try to put them together... the system just doesn't boot.
My motherboard can deffo support this as it's a DFI LanParty that can support up to 4GB.
I have also tried seating the modules in different slots to no avail.
I tried altering the RAM voltage and that didn't work either. By default the DRAM voltage is set to 2.6Volts. I tried setting it to 2.7 and it I still had the problem. Would cranking this higher be a viable solution do you think?
AMD Athlon 64 3700+ 939
DFI LanParty Ultra-D
nVidia 7800 GTX 256MB PCI-e
2GB RAM (1x 1024MB Corsair Value Select DDR400, 2x 512MB Corsair TwinX Pro XMS DDE400)
Thermaltake ToughPower 750W
Samsung SpinPoint 80GB 7200RPM
Thanks in advance to anyone who can help
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
