Installing a fan controller (Stuck already)
3 Jan 2009
Bedfordshire
I have just got a zalman fan controlller. The problem i have is all my fans are 4 pin molex connections. And the fan controllers is 3 pin square type connections.
So do i have to buy a Ocuk 4pin to 3 pin adapter for ever fan or is there an easier way at all???
Thanks
I'm afraid to say I think you do - there is a multi connector but I'm sure it's the other way allowing several 3pin fans to run off one molex.
Thanks, yeah thats what i wasn't hoping for but it doesn't matter. its going to cost £2 a fan to convert which is a shame.
Thanks for the reply
