Installing a program into Ubuntu, can someone help me please.
Commissario
16 Oct 2002
In the radio shack
It's been a long time since I played around with any kind of Linux so I'm after some assistance please.
I need to install and learn the Tučňák contest logging software.
I've been advised that I should do this within Ubuntu so I've downloaded and installed it in a Virtual Machine.
It's all set up and running but (and this is going to sound really n00by) I really have no idea what I should be doing to even install the program!
Installation instructions are here and the download page is here. Can someone help me with a step-by-step idiots guide of exactly what I need to do to get it installed and working please. I'm sure it's a simple procedure but I don't know where to even start.
You'd be wanting to follow the Debian instructions usually, which are to add a repository and install using apt, but having checked myself, the nice chaps at Canonical have included the software in the Ubuntu repositories.
Go to System > Applications > Software Sources and make sure the 1st 4 check-boxes are selected.
Now open a terminal and type the following command: "sudo apt-get install tucnak2"
Go make a mug of coffee.
Oh good stuff, I added those two lines as said on the instructions and then ran the apt-get command and it installed 2.35. Super duper, thanks.
Now I just need to work out usage but that should be straightforward :)
