About to tackle the same problem myself.
Was going to go for "no more nails"ings two strips of wood to the wall, letting that set then drilling through it one of those splaying metal rawl plugs if I can get ones deep enough for the wood and plasterboard.
Won't work, if the batton is on the radiator side of the platerboard it's just as likely to fall off. No more nails is good stuff but radiators are sodding heavy when they're full.
Just to reiterate these should do it just fine. I've held 60kg on a wall with 5 of them on more than 1 occasion
