This is all you need to do, after the Win 7 install load the Intel Intel(R) Rapid Storage drivers if you are using an Intel chipset. The latest version is 9.6.0.1014.
Win 7 is SSD aware so you don't need to do anything else with the OS.
However if you have to upgrade your SSD firmware before installing Win 7 then your SATA must be set to IDE in the bios. Remember to set back to AHCI before installing windows.
