Installing graphics card: nvlddmkm.sys error! Help!
Yup no other hardware. Unfortunately I cant test it in another slot because its only a mATX board and small case so only one is usable.
I ran the DDU uninstaller as suggested. Reset and installed new drivers. Didnt help sadly.
One thing I realised is that the GTX 760 and R9 270X are heavily factory overclocked and neither of them work. Where as my old GTX 690, which is all stock, seems to work fine. Could they be too demanding for the motherboard perhaps? Is there a way to easily temporarily remove the factory overclocking to test?
Another strange thing is that the fan on my new Corsair RM650 650w Power Supply never spins! It has a special feature called 'Zero RPM' mode, but thats only supposed to be effective up to 40% load. However even when benchmarking running Unigine and Cinebench simultaneously on extreme mode it doesnt spin! Of course it doesnt run for long before it crashes but surely it uses more than 260W! Maybe its not getting enough power?
Thanks!
Silly question - does it matter which way you use the ATX power connector cable?
It has 24 pins one end and 20+4 pins the other. Does it matter if the 20+4 pins go into the power supply then the 24 in the motherboard or vice versa?
