- 6 Jul 2009
hi,
Do you install your harddrive with the label facing up or down? Or does it not matter. Could reliability be affected if it was to spin while it was 'upside down'. Does manufacturers test using just one orientation. My new HD is from WD and they do not say which way to install.
