Installing MEDIA CENTRE 2005
3 Nov 2003
Lancashire
hello, just after a bit of help please
built a new system and im having a few problems.
when istalling a clean instance on WMCE 2005 it installs from CD1 then asks for CD 2, then it asks for Service Pack 2 CD !
at this stage I got on my spare pc, extracted the SP2 exe I had and burned the contents to a CD.
put this cd in my new build and it couldnt find the files it was after on its own, i had to point it to the right folder. but it seemed ok, it then asked for CD1 again and the install was done.
now this way of installing has worked on 3 different occasions without any issues.
now on my new system, everything appears to be fine. unitl that is I try and run the media centre console. all I get is a BLACK screen, can still see the white cursor though, so the monitor has switched off, and i can even close down the console by clickin the top right hand corner of the black screen. its weird, everythin gelse is fine, games demos etc. its just the media centre console
I have the following system
Asrock 939 dual SATA 2
Opteron 146
Nvidia 6800GT AGP
2 gig of corsair memory
i know thi smobo is a picky bugger but i have done the following to avoid all of known problems
Fresh install of OS
downlaoded latest intergrated 2.13 AGP drivers
check the ULI agp driver shows in the system devices
instal the latest Nvidia GPU drivers.
Does anyone have any idea or can shed any light on this. should it ask for the service pack 2 cd or not ?
getting a little miffed
when you're download the drivers for *** gfx card, select Media Centre as your operating system, no xp!
try that
well tried again
formatted HD
installed WMCE this time putting in cd 1 when it asks for service pack 2 cd
downloaded latest ULI drivers and installed them
checked AGP driver installed
Rebooted
updated windows
downloaded latest WMNCE edition Nvidia drivers
rebooted
STILL BLACK SCREEN WHEN I LOAD THE MEDIA CONSOLE :-(
you don't use reforce or any other refresh rate forcer do you?
when i use reforce it stops MCE from working..
also, have you tried a different monitor?
ah - I had problems with the lastest nvidia drivers - in fact IIRC it was the same problem, you have to use a previous version try this one
Kev
/edit - if no luck I can upload the drivers I'm using later for you (won't be until after 7 tonight though)
thanks mate but i got it working now. no idea how, spent an hour installing and unistalling drivers. and then out of the blue it started working :)
just backing everything up now its all working sweet.
